Add the specialty accessories–Dadoing, Shaping, Molding, Joining, Mortising, Routing and Drum Sanding–to your Shopsmith Woodworking System and you’ll be able to add professional finishing touches to your projects. Touches such as decorative edges, interesting surface designs and unique joinery.
Grinding and sharpening accessories such as the Grinding Wheel (Figure 1-14) and the Sharpening Guide (Figure 1-15) will enable you to sharpen lathe chisels, shaper cutters, and jointer and planer knives. Sharp tools are very important. They cut easily and more accurately, and are safer to use.
When you add the specialty machines–Lathe Duplicator, Biscuit Joiner, Routing System and Strip Sander–you are set for practically any operation. The lathe duplicator (Figure 1-16) lets you make identical turnings such as matching table legs or spindles for a railing quickly and accurately. You can also do freehand turning. The routing system (Figure 1-17) helps you create duplicate workpieces with the use of fixtures and templates. It is also used for creating decorative surfaces and edges on workpieces and many types of joinery. The strip sander (Figure 1-18) will sand the internal and external edges of projects, sharpen tools, and perform buffing operations.
The entire Shopsmith Woodworking System is even more appealing when retractable casters (Figure 1-19) are installed on the Mark V and Power Stands. The casters are designed for easy installation and quick positioning of the machine to be lifted either 1/4″ or 1/2″ off the floor. When the casters are in the neutral position, the machine rests solidly on the floor.
Back to Introduction
