Find Your Part
- Use the zoom tool, mouse wheel, or pinch to zoom on the diagram.
- Click/touch and drag on the diagram to find your part.
- Click/tap on the reference number in the diagram, or enter it here to filter the parts list table below.
Show Part
Need Help?
Call Shopsmith U.S. Based Customer Care — 937-890-5197Monday - Friday 8:30 am to 4:30 pm Eastern Time.
Email Customer Care — customerservice@shopsmith.com
Parts List:
Ref # | Part # | Description |
1 | 513393 | Planer Anti-Kickback Assembly Long Tube Spacer |
2 | na | Washer |
2 | 513794 | .031" Thick Shim Washer |
3 | 513369 | Planer Anti-Kickback Wedge |
4 | 513394 | Planer Anti-Kickback Assembly Short Tube Spacer |
5 | 513395 | Planer Anti-Kickback Rod |
6 | 513385 | Planer Sprocket-Locking Cotter Pin |
7 | na | Pivot Arm |
8 | na | Special Washer |
8 | 513733 | Planer Special Washer |
9 | na | Pivot Screw |
10 | 555115 | Planer Serrated Steel Infeed Roller Upgrade |
11 | 513391 | Planer Feed Assembly Woodruff Key |
12 | na | Spacer Washer |
12a | 514534 | Planer Outfeed Roller Kit |
13 | 502899 | Jointer Cutter-Head Knife Leveling Screw |
14 | 502051 | Set Screw |
15 | 5035769 | |
16 | na | Ball Bearing |
17 | 513406 | Planer Feed Motor Mounting Screw |
18 | 513363 | Planer Cutterhead Wedge |
19 | 505982 | Planer Knives (Set of 3) |
20 | na | Cutterhead |
21 | na | Chip Deflector |
27 | 51413703 | Planer Elevating Crank Assembly |
28a | na | Special Washer |
28 | 514036 | Planer Table Connector |
29b | 513794 | .031" Thick Shim Washer |
29c | 51398901 | Locking Set Screw |
29a | 513857 | Jointer Swing Guard Lock Nut |
29 | 51399401 | Planer Table Locking Set Screw |
30 | 513397 | Planter Table Elevating Screw |
31 | 514039 | Planer Table with Stainless Steel Skin |
34 | 514037 | Planer Table Connector, Barrel Nut |
35 | 513380 | Planer Stock Thickness Scale Pointer |
36 | 513986 | Pan Head Screw |
37 | 513730 | Planer Tie Bar and Bushings |
38 | na | Shim Washer |
39 | na | Tension Adjustment Sprocket |
40 | na | Roll Pin |
41 | 513387 | Planer Table Elevating Chain |
42 | 513414 | Planer Knife Setting Gauge |
43 | 51368601 | |
44 | 51368604 | 3/16" Short Arm Hex Wrench |
45 | 513391 | Planer Feed Assembly Woodruff Key |
45 | 51368607 | 1/8" Hex Short Wrench |
46 | 51368605 | 3/32" Hex Wrench |
47 | 513348 | Planer Front Top Cover |
48 | 514207 | |
49 | 513191 | Socket Head Screw |
49a | 513386 | Socket Head Cap Screw |
50 | 120380 | Washer |
51 | 51336001 | Planer Drive Hub and Coupling Cover |
52 | na | Left End Frame |
53 | 513782 | Screw |
54 | 449613 | Screw |
55 | 51372304 | Shopsmith Logo Name Plate |
56 | 518386 | Planer Cover with Warning Label |
56a | 516540 | |
57 | 513738 | Planer Rear Cover Pivot Screw |
58 | 513752 | Planer Outfeed Cover Logo Pivot Stud Retaining Ring |
59 | 513376 | Planer Feed Roller Tension Screw |
60 | 513389 | Planer Feed Roller Tension Spring |
61 | na | Right End Frame |
62 | 513720 | Planer Rear Cover Latch |
63 | 513721 | Planer Rear Cover Latch Spring |
64 | 513722 | Planer Rear Cover Latch Shaft |
65 | na | Spring Washer |
66 | na | Bearing Support |
67 | 513739 | Flat Washer |
68 | 120214 | Lock Washer |
69 | 513795 | Screw |
70 | 513402 | Planer Feed Roller Gear |
71 | 513857 | Jointer Swing Guard Lock Nut |
72 | 513746 | Planer Stock Thickness Scale |
73 | 513381 | Planer Chain Tension Sprocket |
74 | 513375 | Planer Chain Idler Sprocket Pivot Screw |
75 | 513793 | Planer Chain Tensioning Bracket Mounting Screw |
76 | 513368 | Planer Chain Idler Sprocket Bracket |
77 | 120392 | Flat Washer |
78 | 115546 | Lock Washer |
79 | 120375 | Hex Nut |
81 | 51335601 | |
82 | 513743 | |
83 | 514690 | MARK-Mounted Thickness Planer Feed Motor |
84 | 513406 | Planer Feed Motor Mounting Screw |
85 | 502973 | |
86 | 513735 | Planer Feed Motor Retaining Ring |
87 | 513403 | |
88 | 51341503 | |
89 | 513411 | Planer Control Box Safety Key |
90 | 513760 | Planer Control Box Mounting Screw |
91 | 514736 |
